I have a 2012 Ford E250/350 2Wheel Drive, Gas, 5.4L FLEX Fuel V8 with Class V hitch and Brake controller, with wheelchair Lift.
First a little history, this is/was a wheelchair lift van for school children/adults. The company lost there contract with the school (Covid) closed. Had to sell off all of there vehicles.
This vehicle went in for service every Monday (I guess required) My mechanic states they are incredibly serviced. It runs extremely well just turn the key and engine just purrs. No smoke nothing, passed smog in CA and have pink slip in hand.
So lets get the first part out of the way..............
Miles 231000 so if that is something that you have an issue with.... I won't try to change your mind. (just a note so one of these vans had 440000 miles on them and running just fine.
I think mine has a newer transmission, not sure but this thing runs great.
This vehicle needs to be completed converting and I am now going to list what you get with the van.
By the way I see one listed for $ 140,000.00 completed.
So I am going to take $ 110,000.00 off of mine to start.
It comes with the following:
Older EX2200 Honda generator cage not inverter type
Flat screen TV with hookup for computer
Goal Zero 1000 watt solar generator Lithium model with vehicle charger and 2 100 watt Newpowa solar panels (mounted)
King Koil inflatable bed (new)
Joolca HOTTAP portable water heating system (please watch the video)
https://youtu.be/cnaPp586By0
That is still on the way should be here within a week (So Yes New)
2 (two) new E-Bikes I-Zip, both are red with lights
https://www.izipelectric.com/e3-brio-step-thru.html
New Coleman propane stove with burner and grill combo Coleman 2000020929 Camp Propane Grill/Stove (NIB)
LED Lantern (NIB)
The van has 2 fold down seats in the back (can be removed).
Has a full not skid floor system with L-Track Single Stud Fitting with Round Ring 4,000lbs Capacity in 4 different locations for tie downs.
New in dash radio with DVD, backup camera touch screen (just installed don't know much about it.
Almost all lighting replaced in side and out with LED. (saved the headlights as the new one might be too bright.) LED light bar in lower front grill.
Tires are new everything works.
High top under 6 foot should be able to stand inside.
Oh Massimo 52 quart refer.
https://www.ebay.com/itm/29399049153...evt=1&mkcid=28
This runs 24/7 with the Goal Zero on solar, states it can freeze as well. Never tried it.
Hitch is over rated for this vehicle (new) brake controller just installed as well.
I'm sure I have more but this should get a start.
I also have a 3 wheeled mobility scooter with new batteries and will swap for the E-bikes.
