21g Valtera Fresh Water Tank (unused) - Seattle - $60
Selling a 21 gallon fresh-water tank made by Valtera. It was pulled from the assembly line where I work because it had a leak - I used ABS putty sealant to seal the leak and have tested it to verify that the leak is fixed. Retails for $113 new on amazon, asking $60. It has never been used, other than filling and emptying it a couple of times to verify that it does not leak anymore.
Dimensions: 8" x 16" x 42"
Tank is black and has internal baffles to help minimize weight movement when the water sloshes around in a moving vehicle. We've used these in the trailers we build for years and they work great. 2x npt to barbed fittings currently attached to tank will be included (hose tubing will not be).
Located in Seattle, shipping is likely not feasible due to its large size.
