SOLD: 4x4 conversion temporary parts
I used these parts to temporarily keep my van rolling as a 2wd when i converted my van with the MG Metalworks kit for the front axle install. This lifted up my rear and adapted the track width and bolt pattern for the stock rear end until I installed my sterling rear. I am also including an adapter I made to relocate the transmission cross member back behind the radius arms and drop it in preparation for the future when I did the transmission conversion to install the transfer case. I eventually did a tail housing 4x4 adapter for my 4r75w and it came with the cross member drop bars, I am including those as well because I modified my cross member before I bought the tail housing adapter kit from expo vans/MG Metalworks. So these are all parts I used as a temporary measure for about 2,000 miles until i did my phase 2 of my 4x4 conversion. Included are 2" Billet Aluminum spacers that change the bolt pattern from 8x165.1 to 8x170, 9/16-18 acorn lug nuts with a 3/4 or 19mm hex size to fit in the wheel spacer adapter lug wells, 5" tapered lift blocks, 12" long u-bolts, home made transmission mount relocation adapter, and transmission cross member weld on drop bars. I spent $350 on this stuff and about 5 hours fabricating the transmission mount drop relocation adapter. I'm offering everything for $200 plus shipping at your expense and choice of carrier or local pick up in Orange County, CA
