AEM HD Water Injection Kit with 5 Gallon Tank for ; Duramax; Powerstroke; Cummins
This is a brand new kit in box. Sold my E350 and forgot I had this kit in the garage. This kit reduces EGTs and inlet air temps on turbo-diesel and gas applications. Asking $350 + shipping. If local to San Juan Capistrano, CA, hit me up for miscellaneous free oil, filter, parts for Ford E350. Moving, so I've got to clear my garage!
WHY USE AEM's WATER/METHANOL INJECTION KIT?
The new HD Water/Methanol Injection Kit is specifically designed for turbo-diesel and gas applications and includes multiple jets to suite your car or truck's power needs. The kit reduces air inlet temperatures and EGTs, which allows you to increase boost pressure and advance timing... leading to more power and safer operating conditions!
NO HIDDEN COSTS... EVERYTHING IS INCLUDED!
The HD Water/Methanol Injection Kit includes all the features necessary to do water/meth injection right. No hidden costs or optional components are required. Unlike other popular kits on the market, AEM includes a five-gallon tank with a fluid level sensor standard. Another standard feature is the boost-dependent, variable-flow progressive controller, which determines the amount of water/methanol mixture (up to 50%) to feed into the inlet stream. Flow adjustments at the inlet are made via three supplied jets that are designed to match most engine power requirements.
BOOST SAFE ENSURES ENGINE PROTECTION.
Also, because AEM's engineers believe engine protection is a requirement, not an option, we include our Boost Safe output in every controller we design. This feature allows you to retard timing or reduce boost if the system runs out of fluid or detects an error. With an AEM HD Water/Methanol Injection Kit, you get all the best features in one low-priced kit.
FIVE-GALLON TANK DIMENSIONS AND MORE INFO.
The new five-gallon tank that is included in the HD Water/Methanol Injection Kit measures approximately 21-inches in length, 8-inches in width, and 10-inches in height. The tank is constructed of high-density polyethylene, which is very resistant to chemicals and moisture, making the material ideal for your water/methanol mixture. In addition, mounting the reservoir will be safe and secure with reinforced 1-inch mounting tabs that are located at each corner.
KEY FEATURES
Kit includes everything needed for installation
Large-capacity 5-gallon reservoir with integral fluid level sensor
Boost Safe lets you retard the timing or reduce boost if the system runs out of fluid or detects an error
Progressive, controller-driven 150-PSI pump provides boost-dependent variable flow
Dash light relays system status and low fluid warning
Methanol & alcohol compatible (up to 50% in solution with water)
Includes three jets to match your power requirements
Reduces exhaust gas temperatures (EGTs) and inlet air temps on turbo-diesel and gas applications
