AIMS 1500 watt modified sine power inverter with built in charger and transfer switch. It was in my SMB when I bought it, but I switched it out last year and went with a 600W pure sinewave since I mostly use the inverter for my fridge and charging my electronics. I recently moved and can't find the AC input cord. If I find it, I'll put it in the box.
The unit is a 1500 watt power inverter, with a 12 volt dc input. This inverter charger has a built in transfer switch which allows you to plug it into a regular ac outlet to automaticallyswitch to run off of your battery bank. The charger which is built into this power inverter outputs 10 dc amps of charge to keep your batteries full. $175 + $70 shipping. I checked with my UPS store and they estimate shipping to be about $70, worse case. If you pay with PayPal, I'll refund the difference between actual and the $70.
Additional Info- DC Input Voltage 12V (9.8-16V)
- AC Output Voltage 120V
- Output Wave Form Modified Sine Wave
- Output Power 1500W
- Efficiency Over 90%
- Charger 10 A Smart Charger
- No Load Current 1 Amps
- Dimensions (LxWxH) 15.63" x 7.75" x 3.25"
