Hey all!
Wanted to let you guys know we have a Transit for sale. This van was used for 2 seasons as a rental for our sister company ROAMERICA. The van is in excellent condition with light wear throughout. Everything works as it did when new.
Interior condition is B+ with some noticeable wear in highly used areas.
Exterior is B+ as well with no significant dents but a few scratches.
We also listed it on Craigslist and the link is below for additional pics.
We design our layouts to be versatile enough for big trips but light and functional enough for use as a daily driver.
This design is called the REVOLVER.
A Modular design allows for the lower jack knife sofa bed (3 lap belts) to be removed quickly from the L track in the floor, and the 3 piece aluminum upper bunk can be unbolted in minutes.
Upper bunk is 6'x6'
Lower Jack Knife seat in bed mode is 6'4 x 52"
Sleeps and seats up to 5 or strip it down so you can fit the big items like bikes, motorcycles, couches, a cord firewood, kegs etc.. Tie down anything you need with the 6' long L-track.
Designed not just for the big trips but also for the daily adventures, or work, or play or home projects. 1 van to rule them all!
The quick and dirty details are:
2016 4x4 Quadvan Ford Transit Campervan - $99,500 (Hood River)
Van has 54k. Interior Conversion was done around 30k miles.
3.7L V6 Motor MPG averages 15.5mpg
Aluminum framed (8020) cabinets with Laminated baltic birch plywood
Thinsulate insulation
2 Maxx Fans
Window coverings
Lonseal Flooring
Blum soft close slides
Southco compression catches for rattle free driving
ESPAR B4L heater plumbed to fuel tank
10 Gallons water via Scepter 5 Gallon cans.
No gray water tank. A portable 2.5 gallon Scepter can be used and included if the new owner wants one.
Redarc Manager 30 for electric management.
Battle Born 100 amp hour Lithium Battery. This has been a perfect size for this van, however, we can upgrade the battery if you want a bigger one. All of our new builds use the Battle Born heated 270a battery.
House Battery charges off alternator, shore power and is prewired for roof and portable solar. No solar panels are currently on the van.
Marine Grade Electrical components through out. All connections are heat shrunk and labeled
Aluminess Roof rack and Ladder
BFG KO2 with 8k miles on them.
I will get a Pre-Purchase inspection next week and if anything needs repair we will get it fixed before the new owner picks it up.
Check it out and let us know if you have any questions or comments.
Our shop is located Hood River, Oregon. If you are flying in we are only 60 mins from the Portland Airport, and we can guide you to some amazing camp spots in the area while you're here.
www.axisvehicles.com
info@axisvehicles.com
https://portland.craigslist.org/grg/...582823996.html
