Our Sportsmobile was totaled after it was sideswiped last November. A replacement has a three year waitlist and costs more than twice what we paid in 2011. Both nonstarters so we're retooling, which means our Adventure Overland Chaser trailer needs a new home. It's the ultimate overland trailer, an Expedition Portal award winner and packed with the features below. The trailer was not involved in the accident. Instead, it was safely parked under the carport at home where it has always lived when not on the road. $13,000 in Santa Fe.
Trailing Arm Air Suspension V.4 with air springs and adjustable shocks. Electric braked axle upgrade with 10"' drums, includes break-away kit. Multi Axis Coupler, 6000 lb, Class III.Rear Stabilizer .
72’ x 50” (40" at wheel wells) x 26.25” (LxWxH) body, rubber matting, cargo tie downs, 2' rear accessory receiver & Chaser 16' x 32' tail gate with locking T-handle latches. Up front there's a steel powder-coated nose box with 12V & 110V connections. On top it has 2 load bars on an adjustable aircraft grade cargo L track suitable for a rooftop tent.
It has an electrical supply for a freezer powered by a 100W Battleborn LiFePO4 heated battery with Victron charge controller. The battery can be charged with shore power or portable solar panels. There's also a propane bracket with a 10lb bottle for a stove hookup.
For water, there's a 19 gallon roto-mold water tank with 3"' opening, 1/2" drain plug and manual pump. There are also 2 CARB, leakproof bayonet closures w/locking pins and two 5 gallons water containers held in place by AT aluminum holders.
There's a 4'x6' 12V LED rectangular HD flood light installed as reverse/work light on driver's side rear of trailer with an over-ride switch.
Addon options: Two 1-Up USA bicycle roof racks ($250), a Yakima Skybox 12 ($400) and 1 or 2 Zamp 140 legacy solar panels with charge controllers ($400 each).
Here are some photos. PM me for questions.
In the shop, being built
Suspension
Nose box
Ready to go
Loaded to go home
Hitched Up
First Camp
Dinner time
