Ford Transit 350 XLT Quigley 4x4 CCV pop top
For sale: 2017 Ford Transit XLT 3.5L Ecoboost 350hp with Quigley 4x4 conversion and Colorado Campervan Pop Top. 55k miles. Located in Chattanooga, TN
$87,500.
Seats and sleeps four. Tow package with trailer brake controller, 10 way power heated front seats, Apple Car play, Lane keeping, Power deploying running boards, rain sensing wipers, remote start and much more.
This is such a great van. I don't think there is anything that did not come stock on it. It was converted by Site Seven and Colorado Camper Van. It does not have a kitchen inside because we prefer to camp out of it, instead of in it. The rear of the van can hold a full piece of plywood when needed, but can be converted into the lower bed. The top allows you to sit up completely and has black out panels, screens, and the screens can be zipped down to open the panels completely. If you don't want the AC, the opening in the roof is the same size as used by the Maxxair fan, so you could just sell the AC and replace it with the fan. I hear two fans work pretty well for circulating the air. See below for a more comprehensive list of it's features. I am sure I have forgotten something, so please feel free to reach out if you have any questions. Well, unless that question is whether it is still available. If the ad is up, it is available.
Quigley real four wheel drive
2” lift
Falken Wildpeak AT Tires
Colorado Camper Van Pop Top
USB outlet and second light switch upstairs
Custom wrap for pop top(top left white to reflect heat)
12v package including:
House battery system
-Lifeline 12v AGM Batteries
-Charge relay
-12v fuse Box and associated wiring and breakers
-4x USB outlets
-12v outlet in garage area Stock inverter under driver’s seat for use when engine is running.
Shore power outlet under rear bumper for roof AC and charging house batteries
Heavy Duty alternator that charges vehicle batteries and then house batteries.
Stock Heavy duty vehicle batteries.
Cover King Tactical Seat covers with Molle backing and storage. Webasto heater.
Maxxair fan.
Coleman AC.
Swivels for front seats.
Rear seats adjusted back 6” to allow for dinette.
Butcher block table.
Custom welded wheel well boxes with slots for bed.
10 gallon water tank with 12v pump.
Hot water heater(with adapter for smaller gas tanks).
Fully insulated .
Sound deadening throughout.
Rear slide for access to supplies under the bed.
Awning with gutter and central support for rain.
Eclipse Sunshade.
