If you don't get a response, let me know and I can take some pictures of mine (have 2 - one one each front corner of my roof rack) and you should be able to get a metal shop to make something functional for you. If interested, Send me a PM and your number and I can text them to you.
I believe there were two types of bracket they made for the GoLights, one that mounted on the front center of the roof rack, and the other for the front corners (I don't believe I've seen another Van with the two corner lights like I have).
If you are looking for any feedback or advise, I would have to point you towards the hardwired version that has a joystick to control the light head unit. Joystick is so much simpler to use, especially while you are driving.
I had the joystick on two boats and you can easily steer with one hand and use the joystick with the other at the same time - joystick is also easier to maneuver the light around. Not so easy to do with the remotes (dash mount or hand held). But...the wireless handheld remote is great when you're at the campsite and suddenly need to turn on the light to scan the area.
