Old 09-02-2020, 08:16 AM   #1
Part needed! Help Ford van part nerds
I am looking for a Rear right break backing plate for a 2000 Ford Econoline 250. Mine has rusted through causing binding. The shop isn't having any luck finding the part and neither am I. Any suggestions or links, or donations would be appreciated.
Logan
Pluglyfe is offline   Reply With Quote
Old 09-02-2020, 10:10 AM   #2
Try searching for a Brake Backing plate. Best bet however will the car-part.com. I’m not sure you will find it new, because typically damage to the brake backing plate usually requires a new axle. And this might apply to yours as well. If the brake backing plate is that rusted, your axle tubes might be compromised.
Tags
2000, break, break plate, e250, econoline
