So while you were driving with the AC running through your inverter you were using probably 120 + amp of power. I doubt your alternator could keep up with that. So I would expect that you ended some amount of power down after that drive.
So if you stopped, the resting voltage of a charged battery would be around 12.8 -12.9 volts.
We don't know how charged up the battery was before so difficult to determine what it would be.
Do you still have the inverter still on?
