We have SS hoses in our home built van so our routing is different from what SMB did on yours.
I guess the first question is what are your current hoses made of. If rubber then replacement may be a good idea. If they are copper they should be fine for the rest of the vans life. This assumes that the copper lines are not rubbing on anything.
One way to tackle the replacement is to figure out how the existing hoses were run. IIRC the routing goes from the tank on the driver to furnace on the passenger side. Most likely under the van along the frame rail and cross members. The replacement lines could follow the same routing.
Hope this helps.
Larrie
