2000 E350 EB50 SMB Quig 4x4
I am in need of a polished or dull original aluminum rim 16x8, 8x165.1 lug pattern, 4.0in backspace, (-11mm ofset stamped on rim inside).
Anyone have old rims to sell me? Need 1 min. because found 1 that developed a crack and leaks air to make tire flat in 30mins-not safe to fix.
I had one of mine crack from overloading, swapped the pair out, and found out the other one (moved to the spare carrier) also cracked when it didn’t hold air anymore.
If that one was on the rear you might be in the same boat...
