I used both the landau top adhesive above and spray headliner adhesive for all of the interior fabric and flooring in my build. They are both formulated for high temps and have worked well in the So Cal heat for 6+ years.
If you are in So Cal A1 Foam & Fabric in Santa Ana sells both, although lately the landau top adhesive has been hard to come by. It's only available in gallons at about $55 each as far as I know.
The Rattle can headliner adhesive is also available online from several sources, including yourautotrim.com
https://www.yourautotrim.com/glues.html
I brush on the landau top adhesive (although it's formulated for spraying) and if the material is fabric it tends to soak in too much; that's when I use the spray headliner adhesive. They are both contact cements and stick to each other really well. ..Just give them a few minutes to tack up before sticking them together.
If you need to stick fabric to solid surfaces you could use spray on both surfaces or brush on the landau top adhesive on the solid surfaces.
...you want the high temperature flavor of contact cement in any case.
