SOLD: 1999 Ford E350 Super Duty Ambulance 4x4
Up for sale is our dream rig, but we have taken a new job and have zero time to build it. $55,000.00 OBO
Located in Morgan Hill CA until July 5 then we are driving it to Bozeman Montana
Will upload more photos ASAP
Just completed a major reset on this 1999 Wheeled Coach type 3 Ambulance. 7.3 turbo diesel Engine is strong and runs great, cold AC, tons of new parts. Insulated interior and is ready for build out for camper, build date 4-1999
Dana 60 front axle, Dana 70 rear axle, NV271 T-case needs installed
37 gallons of fuel
Power door locks
Tilt
Cruise
Front AC
DP Tuner
off road lights
Just drove from Morgan Hill CA to Flagstaff AZ and back, van did great
NEW:
Brake rotors, calipers and pads front and rear
Front brake lines
Master cylinder
Rear parking brake shoes
front and rear wheel bearings
Front Diff cover with drain
Rear Mag-Hytec diff cover with drain and dipstick, high capacity
rear 4:88 gears and ARB air locker
4 inch turbo back exhaust
Heat wrapped up/down pipes
camper ceiling fan
Mag-Hytec Transmission pan with drain large capacity, new filter installed
NV271 transfer case
Turbo rebuilt
8 inch U Joint off road lift kit
U Joint front knuckle upgrade
Pitman arm
Steering box
tie rod ends
ball joints
Leaf springs all four corners
new ABS sensors
FOA 2.5 remote reservoir shocks
Apple carplay stereo with 10 inch sub
Super Duty front bumper with winch
Rear bumper with dual tire carriers and winch
Velvac heated/power mirrors
Dee Zee step boards
New Ford Engine parts:
Bosch fuel pump
Bosch HPOP
HPOP lines throughout
Rebuilt injectors
Injector pressure regulator
glow plugs
glow plug control module
intake heater and control module
Dual alternators = 500 amps
Map sensor
water pump/thermostat
Complete Fuel filter bowl/filter
Oil filter
Trans filter
vacuum pump
Riff Raff overboost protection
Power steering pump
Power steering reservoir
Valve cover gaskets with wiring
Cooling fan and clutch
Fan Belt
Belt tensioner and pulleys
All sensors replaced
Oil cooler rebuilt
All cooling hoses
Bosch AC compressor
AC Condensor
AC Dryer
AC evaporator core
Heater hoses
Block heater
Coolant
Body:
2014 front fenders, hood, grill
2014 Front door panels
Custom bumpers with winch's
Dash AC vents
E-brake switch
Seat belt retractors
Seat belt pre tensioners
Wheel-Skins leather steering wheel wrap
Wipers
Wiper control module
Turn signal stalk
260 watts of solar on controller
4 batteries
2000 watt inverter
30 amp shore power
Dometic Awning with LED lights
