I'm selling a 2000 Ford E-350 7.3L with a UJOR 6" kit on it.
The engine has 400k miles. Literally everything on the engine, but the engine itself has been replaced, including stock Rosewood Diesel injectors.
The Alternator, HPOP, injectors, vacuum pump, radiator, fan clutch, and water pump are all less than 2 years old. A lot newer than others.
I do a oil analysis every oil change and have those reports available.
Van is fully ready to camp.
Queen bed.
30 gallon water tank.
300ah AGM batteries.
200w solar.
Roof top AC with soft start (can run off 110v 15a).
Converter/charger.
Swivel seat.
45 quart 12v fridge.
UJOR 6" kit. 4.56 gears, OX Locker in the rear, TrueTrac in the front.
35" BFG KO2's 85% tire tread left.
Pricing......
The torque converter went out and the van is currently in 2wd mode and in a storage unit near Pittsburgh, PA.
If I get the torque converter replaced, and bring it back to NC, and finish 4WD, $24k.
If you pick it up as is, $20k.
Also, may be included with the sale, but will be removed otherwise:
UJOR OBA System.
UJOR FB-002 front bumper with Warn winch.
Fiamma F45 Awning.
Add another $4k if you want these also.
I work offshore and cannot just show up whenever, things have to be planned out. I will be home on 9/16 for 2 weeks if interested in the van.
Thanks!
