Old 05-05-2021, 07:25 AM   #1
Driveabout's Avatar
SOLD: 2014 Sportsmobile 4X4 – Ready to Explore
Ford E-350 XLT Extended Van – Last year of all steel body construction
27,900 miles – $135,000
Custom built for owner by Sportsmobile West using EB 50 floor plan with motorized penthouse lift to provide upper and lower sleeping areas.
DRIVETRAIN
• 6.8L EFI Triton V10 engine with 5-speed automatic transmission & overdrive
• 4.10:1 axle ratio
• Advanced Adapters Atlas II transfer case
• Dynatrac ProRock 60 front axle
• Dynatrac Pro 80 full-float rear axle
• Warn premium manual locking hubs
• ARB lockers front & rear
• Detachable sway bar
• Dynatrac ProSteer ball joints
• Rancho RS9000XL adjustable shock absorbers
• Firestone Ride-Right rear air springs
• BFG AT KO LT285/70R17 tires (6 tires & rims)
• Motorcraft MAX battery with 850 cold cranking amps
• 225-amp heavy duty alternator
• Engine block heater
• Transmission/auxiliary oil cooler
• Trailer tow package with telescopic side view mirrors & integrated trailer brake controller
• Specialty lubricants: For differentials 17 qts. Torco SAE 85W-140, for transfer case 23 qts. Amsoil SAE 75W-90
ON-BOARD ELECTRICAL
• 3 Dragonfly Energy 100Ah 12V LifePO4 lithium deep cycle batteries with heating blanket & Victron BMV-712 monitor
• 2 Zamp 100-watt solar panels & controller
• Magnum Energy MagnaSine MS2000 inverter/charger, ME-RC50 remote control & ME-BMK battery monitor
EXTERIOR
• LLumar Platinum self-healing paint protection film
• Aluminess 3” slat roof rack with anti-slip tape, Zamp solar panels, Maxtrax & Rigid lighting
• Fiamma F45 10’ awning with tie down kit
• GoLight Stryker halogen remote control searchlight
• Rigid SR2 30” light bar & 4 LED utility lights
• Aluminess side mounted ladder
• Aluminess front bumper with Superwinch Talon 14.0 SR (50’ synthetic rope), Hi-Lift jack, Hella fog lights, air compressor connector & hitch receiver
• Aluminess rear bumper with deluxe box, spare tire mount, upgraded latches, Expedition kit (shovel & axe), Hella backup lights & hitch receiver
• ExtremeAire Magnum air compressor with 2 gal. tank
• Rock Slider retractable steps with lights
• 40-gal. Transfer Flow fuel tank
• 5-gal. propane tank with Extend-A-Flow connector
• 16½-gal. freshwater tank
• 7-gal. gray water tank
• Cameras front & rear
• Backup sensors
• Compustar security alarm & remote
• Essex driver’s door coded keypad
• Bushwacker wheel flares
• 50’ synthetic winch rope extension
• 2 5-gal. jerry cans
• Rotopax 2-gal. fuel pax with lock
• 8-ton US Jack, Safe Jack base & extensions
• Pull-Pal RW14 land anchor
• Hi-Lift jack accessories
• 1 pair Maxtrax MKII with locking mounts
• Trasheroo
• 12V & 110V marine outlets
• 25’ 30-amp shore power cord
INTERIOR CAB AREA
• Ravelco anti-theft device (Can’t be hot-wired)
• Kenwood DDX 9906XR monitor with DVD receiver, Apple CarPlay & speakers
• Kenwood TM-V71A HAM radio
• Leather seats, heated with lumbar support
• Power driver’s seat
• Swivel passenger seat
• Panel gauges: tachometer, fuel, charging, temperature, oil pressure
• Auto-dimming rearview mirror with compass & outside temp
• 2 fire extinguishers, including H3R Performance HalGuard
• Adjustable steering wheel
• Cruise control
• Power windows & door locks
INTERIOR LIVING AREA
• Reflectix Extreme Weather insulation
• Rear bench seat folds flat & has 3 seat belts
• Isotherm Cruise 130 refrigerator
• Suburban 6 gal. propane water heater with Motor Aid
• Suburban propane furnace with thermostat
• 2 Sterno butane stoves
• Microwave
• Danhard rear A/C
• Thetford Porta Potti with padded cover
• Easy access rear storage flips up & has lighting
• Rear, below deck steel storage box with sealed, locking lid
• Detachable spray shower wand located in rear
• Collapsible table
• Door & window bug screens
• Privacy curtains
• LED interior lighting
• Smoke & carbon monoxide detectors
• 12V & 110V outlets
Complete documentation included
Driveabout is offline   Reply With Quote
Old 05-05-2021, 07:28 AM   #2
Driveabout's Avatar
Interior photos
Old 05-05-2021, 07:38 AM   #3
That is a pretty special, low mile, V10 rig. GLWS.
Old 05-05-2021, 07:52 AM   #4
Twoxentrix's Avatar
Wow - Nice Van! I haven't even considered selling mine, and I'm very tempted. GLWS
Old 05-05-2021, 08:13 AM   #5
1der's Avatar
I know this van and the owner.
This van is BETTER than the day it came off the Sportsmobile West line, and even at that point it was exceptional due to the attention to detail that driveabout put into this as it was coming together.
Wow, this is a very special opportunity for someone. There will be a very satisfied new owner and I would expect it will be soon!
Old 05-05-2021, 04:26 PM   #6
Makes me want to sell mine too... but really, for that price there should be a roll of paper towel in the holder above the sink. Golly.
Old 05-06-2021, 07:07 PM   #7
yondermountain's Avatar
Beautiful van! Beyond nicely equipped! I am curious to know what your towing experiences have been? What kind of weight range? What does the van weigh?
J
yondermountain is offline   Reply With Quote
Old 05-06-2021, 09:02 PM   #8
Driveabout's Avatar
Thanks for the comments and questions.
The van weighs in at about 10,500 lbs, depending on how much premixed margaritas and ice cream I'm carrying in the not listed ARB fridge/freezer. (BTW there is a plug installed for the ARB so it can fit snuggly in the back.)
As for the trailer, your question brought back fond memories. I attached a photo of a multi-family gathering at Stovepipe Wells, Death Valley. The little yellow trailer was a Fleetwood Evolution 2 that weighed 4,500 lbs. That trip had us driving over Tioga Pass in Yosemite (10,000') and taking the 9 mile, 3500' climb from Panamint Valley over Towne Pass into Stovepipe Wells. As I recall, not a groan from the beast.
Nice catch, eddyturn. I knew I should have hired someone to stage my van! I'm planning on adding the paper goods as a bonus for the lucky buyer.
Old 05-07-2021, 03:14 PM   #9
What is your fuel economy on highway vs city?
gsrthomas is offline   Reply With Quote
Old 05-07-2021, 03:29 PM   #10
1der's Avatar
City 10 smiles per gallon from watching people oooooh and ahhhh and point
Highway 100 smiles per gallon because you know you are either on your way to someplace great to meet friends or no one at all, or if on the way home, knowing you just had a great time in your awesome comfortable capable rig in places not many people get to.
Off Road - 1,000,000 smiles per gallon because you can do it!!
Parked in your driveway - Infinite smiles per gallon because it is your escape pod and connection to sanity!!
Lifetime mileage - memories to be cherished, shared, and reflected upon with family, friends, and acquaintances
