I have an extra Expo Van Conversion kit powder coated and ready for install. Just supply a Ford Nv271 or 273 Transfer Case and '13-'16 F250 or 350 radius arm front axle. Basically bolts on. I have documentation and links to the online support forums. These conversion kits are made in limited numbers.
Asking the Invoice cost $2170
My cost was slightly higher with powder coating.
Located in 95451
From Expo Van:
Background/information on our coil spring 4x4 conversion bracket kit;
The conversion kit we designed/engineered was intended to be the most straightforward way to install a 2005-2016 F250/F350 4WD front axle under a 4th gen ('92-14) E-Series van, with no welding required! We like to recommend '13-'16 axles however due to the larger 14.3” brakes being standard on these later model axles. To go one step further, the '16 axles have MUCH larger knuckle joints and since they're still a pretty recent model year, you can sometimes find a good low mileage axle for not much more than the older ones (car-part.com, Ebay, Craigslist are all helpful SRW(single rear wheel) axle sources).
With all of the in-house builds and development projects/products we have going on, we don't have the capacity to perform installations in-house, so we will not be scheduling any. We are just selling the bracket kits we designed. What will be included in the CAD-designed, laser cut, CNC-formed and welded bracket kits are; two radius arm brackets, two spring perch&shock mount brackets, two coil spring keepers, trac bar mounting bracket, and machined pitman arm (no powdercoat on these brackets, just raw parts so that you can powdercoat them in whatever finish you desire). For "special pricing," scroll to the bottom of this email.
The remainder of the parts needed for the 4x4 conversion are readily available from online and local sources and we see no need to have parts shipped from all over the country to our shop, just to repackage them and ship them out to you. Plus, we're trying to save you money here to go towards your 4x4 conversion! All of the part numbers for the off-the-shelf parts are well documented and are provided to you (see att'd). Note that we have LIMITED resources for or providing support for questions regarding the bracket kits, and installation, etc; this is one of the many reasons for this special deal and price. The online community is welcome to share knowledge with each other as everyone builds their vans. Please refer to the forum (Sportsmobile Forum, Expedition Portal, etc) threads for answers to any questions you may have, such as his thread;
https://www.sportsmobileforum.com/fo...are-22440.html
