Old 07-19-2021, 10:12 PM   #1
b. rock's Avatar
SOLD: Yellow EB Shuttle Top/High Top
Professionally removed Ford EB high top, a la shuttle top style, presumably vintage 2006. If you're 5'8" and below you should have standing height, which puts it at a 16"-18" top. My wife is 5'10" and it was just too short for her to stand, as a reference. If someone can tell me where the 'official' height of a top gets measured, I can pull a tape and measure it but 16"-18" is the range I see walking around it. Edit: this is a reverse flange top, and is bare fiberglass on the other side.
Comes with pre-installed fantastic fan, plus the controls.
Small hole drilled right above the cab area - maybe for an antenna? Not sure, was there when we got the van. Otherwise no leaks/cracks/etc.
Located in Evergreen, CO.
Not 100% what these go for, especially with the fan already installed, so let's start at $1500 OBO with you picking it up. If I have to deliver it along the front range, let's chat as I'd have to rent a trailer.
For what it's worth I picked it up from Timberline using a U-Haul car trailer - it straddles the open center just fine.
b. rock is offline   Reply With Quote
Old 08-23-2021, 09:53 AM   #2
b. rock's Avatar
Bump, $1k OBO. Need it gone before the snow flies.
Old 08-26-2021, 10:15 AM   #3
aw man. If it were just a few more inches taller, that would be on my van. I am 5-10 and need standing height.
Good luck with sale!
MOTOMINDED is offline   Reply With Quote
Old 08-27-2021, 08:17 AM   #4
gahamby's Avatar
How difficult would it be to extend the height?
'07 GMC 2500 6.0
Old 08-28-2021, 10:40 AM   #5
If you were closer I'd consider it as a candidate for pop top make over since it is the shortest of the tops. I am presently working on reinforcing a new RB 20" to a pop top. If it works out I have two more I will do or sell as built.
Old 08-28-2021, 11:08 AM   #6
b. rock's Avatar
I thought about making it into a pop top but I really like fixed high tops so I paid for the new one. I'm not opposed to meeting somewhere in the middle - AZ? Closer to thanksgiving for a mtb road trip.
Height extension might be tough since it's reverse flange. I imagine you'd cut the flange, add the height, then reattach the flange.
Old 09-07-2021, 06:17 PM   #7
Is this still available?
Eney is offline   Reply With Quote
Old 09-08-2021, 07:27 AM   #8
b. rock's Avatar
Yes
"The message you have entered is too short. Please lengthen your message to at least 10 characters."
Old 09-20-2021, 09:00 AM   #9
b. rock's Avatar
Sold!
