08-05-2016, 04:56 PM
Ya, I am glad I found one local that sorta already fit what I wanted because it's turning out to be exactly what I wanted.
The other thing I forgot that's also a big plus is the black/tan combo. Hard to find and I think it looks super good.
08-05-2016, 05:47 PM
Originally Posted by Jsweezy
Before you go and buy all the UJoint stuff I would talk to MG about what his kit has to offer. And no he won't talk you out of a UJoint kit, but he may talk you into an MG kit.
Definitely take a hard look at this van either way. I wish I could buy it.
I have never looked at MG so far but will do so and take MG and UJOR specs to mechanic to discuss when I get a van.
Sent you a pm if you don't mind commenting? Thank you!
08-05-2016, 07:47 PM
V10s are also a lot easier to convert because of the 5 speed which I think makes driving so much smoother.
Not sure what you're saying here? You prefer the 5 speed for driveability, or they're easier to convert for some reason? I've never heard anything about the latter.
08-05-2016, 08:19 PM
Ha ha I guess both.
I definitely prefer them for drivability, quick starts if I need to along with easy cruising on the freeway.
The 5 speed transmission doesn't need to be removed in order to get it ready for a transfer case. I am not sure all of the details but from what I understand its sort of a plug and play type deal before you attach the transfer case.
08-05-2016, 11:51 PM
The TorqShift 5R110 has a rear tail shaft and housing that can be easily exchanged from 2wd to 4wd without removing the transmission or tearing it down.
AgileOffRoad.com
08-06-2016, 07:14 AM
And for reference I have found our EB v10,3.73, and 4r100 to be plenty fast off the line and never felt I needed a lower gear. The 7.3/3.73/4r100 without a tune feels like it could use another gear compared to the V10. Adding a tuner resolved the off line sluggishness. I am guessing the 5.4/5r110 is probably a nice combo. I would have liked the 3/4/5 gearing to have been where the difference was)
4r100 gear ratios:
1st - 2.71
2nd - 1.54
3rd - 1.0
4th - .71
5r110 gear ratios:
1st - 3.11
2nd - 2.2
3rd - 1.54
4th - 1.0
5th - .71
08-06-2016, 07:36 AM
See, you really do learn something every day!
08-06-2016, 10:09 AM
Good info from all. Owner said the wheels are wide with 'road towing' tires on it, I'll find out exactly what. But what do I need to consider for wheels/tires if I convert v10 to 4x4?
I know Quigley told me the other day a ford needs 16" wheels up sized but a GM would not...
Thanks
08-06-2016, 10:54 AM
Depends on who you go with for 4X4 conversion and what front end components are swapped in. Quigley and others? famously (at least used to) keep the E series 8X6.5 bolt pattern making it difficult to find off the shelf parts like front rotors without the need to re-drill them to fit. Many others keep the donor axle 8X170 and convert the rear 8X6.5 with spacers/adapters making it much easier to find parts. I just had a super duty front end put in my project van with rear spacers/adapters to fit 17" 8X170 with 285/70/17 tires.
08-06-2016, 11:38 AM
#20
I agree here, go with the 8x170, rear spacers and 285/70/17s. Thats what I did and am very happy with it.
