Old 07-10-2022, 08:22 AM   #1
Under Chassis Insulation - Water Pipes ?
Greetings -
Sorry if this is redundant post - but wondering how owners insulate their undercarriage water/sewage/holding tank(s) piping ? Are you using standard foam and "liquid nails" or silicone to attach insulation ? What have you found that holds up the best solution over the years of ownership - running forest roads, beach and sand, etc. ?
Details welcome -
Old 07-10-2022, 10:06 AM   #2
I meant to specify "round pipe foam" rather than any type of "sheet" foam - as personally I can't see how sheet foam could adequately wrap around plumbing pipes.
Old 07-10-2022, 01:09 PM   #3
We use the round foam pipe insulation from the hardware store. It has held up just fine after 15 years.
— gordon
gordon is offline   Reply With Quote
Old 07-10-2022, 01:54 PM   #4
Thanks "gordon" -- applied with liquid nails or something else ?
Old 07-10-2022, 01:55 PM   #5
marret's Avatar
Me too, just used zip ties to secure and I also ran a pipe warmer wire. Just had mine on since Mar so can't speak to durability.
Chris
Old 07-10-2022, 02:52 PM   #6
No other adhesive beyond the tape strip that comes with the split insulation. Just put the split insulation over the pipe, peel the backing off of the attached tape, and press.
Old 07-11-2022, 09:59 AM   #7
Be aware they do sell a cheaper non adhesive model.
Buy the most expensive model they have. Better adhesive and better foam.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
LiamMobile
Shyll
Dusty
capnkurt
