Nice, used inverter for sale. Fully functional when removed from an RV trailer to upgrade to a higher capacity system. Was used for roughly 2 years. Specs are listed below:
- 2,000 watt continuous max draw
- 6,000 watt surge max draw - this is pretty rare for this size inverter (as far as I know). Most max out at 3-4k surge.
- Charger and inverter (allows you to run systems & charge batteries off of shore power)
- Includes remote panel that allows easy control over the system (scratches on remote screen are actually just the standard plastic protective piece that is meant to be peeled off after install)
- Weighs 42lbs, roughly 17 1/2" long, 8" tall, 8" wide
- I have experience installing these systems, I can provide some help with setting it up
Asking $450 OBO - these aren't sold anymore but they retailed for right around $1,400 new. Located in Seattle, WA - shipping MIGHT be possible, but likely cost prohibitive due to the weight of the inverter. Also listed locally on craigslist/fb marketplace.
