SOLD: Yellow EB Shuttle Top/High Top
Professionally removed Ford EB high top, a la shuttle top style, presumably vintage 2006. If you're 5'8" and below you should have standing height, which puts it at a 16"-18" top. My wife is 5'10" and it was just too short for her to stand, as a reference. If someone can tell me where the 'official' height of a top gets measured, I can pull a tape and measure it but 16"-18" is the range I see walking around it. Edit: this is a reverse flange top, and is bare fiberglass on the other side.
Comes with pre-installed fantastic fan, plus the controls.
Small hole drilled right above the cab area - maybe for an antenna? Not sure, was there when we got the van. Otherwise no leaks/cracks/etc.
Located in Evergreen, CO.
Not 100% what these go for, especially with the fan already installed, so let's start at $1500 OBO with you picking it up. If I have to deliver it along the front range, let's chat as I'd have to rent a trailer.
For what it's worth I picked it up from Timberline using a U-Haul car trailer - it straddles the open center just fine.
