Good explanation Wowbagger. The important difference between 12v systems and 120v systems is the current draw that requires much larger cable sizes. 1200w is 10 amps on 120v and 100 amps on 12v. A #14 wire is OK for 10 amps. As you might expect, 100 amps requires a cable 10 times as large roughly.
