I mounted ours directly to the metal floor using the supplied mounting plate and gasket as well as silicone and a filler piece where the metal floor was lower. As you said, cutting out a section of the plywood (rubber in your case) floor a bit larger than the size of the whole unit. You will find mounting directly to the metal van floor the final solution. Make sure to have some POR 15 or similar to coat and seal the exposed cut metal edges. I found it easier in the end to cut one larger pass through (I seem to remember a template) for the combustion air/exhaust and fuel line. The hose clamps securing those hoses are awkward to tighten.
I did bench test my unit before install. I put some diesel fuel in a clean jar. Gave me a feel as to how much heat comes out of one of these things! Also made me realize the combustion exhaust pipe needs some clearance because it gets hot.
High Altitude kit - this was/is a head scratcher for me. At least in what I received, the instructions were not helpful. What could be an easy plug and play add-on is cut and splice and add and solder and what wire goes where challenge. I researched many sources and still did not feel comfortable I got it right. If anyone has the definitive answer/ schematic on this please post it! I was advised it was prudent to add a high altitude bypass switch for troubleshooting situations but I never do because I was not sure which wire(s) to tap the switch onto.
I cannot help on the fuel tank pick up install. I add a larger 40gal+ Fuel tank from Aerotank in San Bernadino. I requested two aux fuel pick-ups be included. Just be careful if doing this because the diameter of the fuel pick up tube is important for proper fuel draw. What a I did works fine. If I were doing it again, and had the foresight and parts, I would have sent the Espar fuel pick up tube to Aerotanks and had them install that in the tank plus a second aux pick up.
