Those are pretty cool too---I've seen them in larger sizes as well for securing larger wiring harnesses as needed.
Good find!
This is another alternative if you want to drill 1/4" holes vs use the screw-down type. Basically, I opted for the screw-down because the base is wider and likely to hold larger cables better.
