Old 07-27-2015, 11:37 AM   #1
A little polishing
Picked up my van on Friday from UJOR.....no I did not get the 4wd treatment....I had a new front suspension installed on my 1997 561k mile van. Needed to clean off a few bugs and decided to do a little polishing. The reflection is my supervisor JADE
hogasm is offline   Reply With Quote
Old 07-27-2015, 06:25 PM   #2
Viva's Avatar
Re: A little polishing
567,000 miles?! Wow, rock on
Looking pretty good, too.
(Just curious, which engine do you have? I have a 1998 V-10 and I sure hope it takes after your van!)
Old 07-27-2015, 06:38 PM   #3
Lookin good. Lets see the whole thing. Did you get a lift put on? What size tire is that?
jydog is offline   Reply With Quote
Old 07-27-2015, 06:39 PM   #4
It is a stock 7.3
Just replaced the injectors, under valve cover gaskets, glow plugs.....etc.....
Still have not touched the tranny why did I say that
Old 07-27-2015, 06:44 PM   #5
The tires are 305 70 16 BFG's
Chris installed the front suspension brakes from a 2014 under her. I have 2" over sized coil springs in front, rear is stock
The 305's fit with the stock springs, but I wanted to give the van an even stance
Old 07-28-2015, 01:20 PM   #6
Pic of the side showing the room for the 305's
Old 07-28-2015, 01:21 PM   #7
mikracer's Avatar
What springs did you use?
Old 07-28-2015, 01:21 PM   #8
Rear pic
Old 07-28-2015, 01:45 PM   #9
Moog cc860
I will try to post the front end alignment
FRONT LT ---------- FRONT RT
actual------------------------------- actual
0.4 camber specified range 0.0-1.0------ 0.8
1.4 caster specified range 2.0-7.5------ 1.8
0.04 toe specified range -0.10-0.16------ 0.03
FRONT
actual ---------------- specified range
-0.4 Cross Camber -0.5-0.5
-0.3 Cross Caster -1.0-0.0
1.3 Cross SAI
0.07 total toe -0.19-0.31
REAR
-0.08 Thrust Angle -0.50-0.50
As you can see the Caster is off -0.6 on the left and -0.2 on the right from the minimum.
These are the #'s we came up with after doing an alignment. The van runs straight, does not pull any but does like to follow the groves in the road easily. Am going to give a single steering stabilizer a try to see if it helps.
Old 07-28-2015, 04:23 PM   #10
Nice ride!!!
thestoneman is offline   Reply With Quote
