Did I understand correctly that you'll have the option of a 65g (3rd) gas tank off of the rear bumper?? If so... that must bring your total capacity to 100-something gallons? That would be incredible.
2003 E250 Full Self-Build
2009 Honda Element "lil' toaster"
2013 Suzuki DR650
Santa Cruz, CA
I have the original 55g tanks behind the rear axle and a 2nd 50g or so (the aluminum one pictured previously) located along the frame. Then I have a 3rd larger 65g aluminum tank for the rear bumper.
I run my truck on veggie oil so typically I fill the oem tank with diesel and the 50g with veggie. The 3rd tank will also be for veggie.
So all in, around 170g (645L) of fuel available for those roadtrips
2008 E350 Hambo
2001 E350 AmbuLand (sold)
1970 Econoline popup camper
1965 Econoline Travelwagon
Yes! I've designed it to fit alongside the poptop.
Now, I don't expect I'll be able to use it with the top opened but it could work especially if I place an extra spark screen by the chimney. I think the main concern might be smoke...
2008 E350 Hambo
