A lot depends on the construction of your top. Mine has a similar but not identical top. I can't see the underside of my top since it's covered by a headliner that also has A/C vents down the center.
I removed the panel hiding the cavity over the cab and was able to take a cell phone photo, looking to the rear, that shows two longitudinal stringers that are fiberglassed in. I'm thinking they're wood but they could be fiberglass channels. This is good news for attaching solar panels (which is why I was looking) but could be problematical with respect to vents. I wouldn't want to cut them and compromise the rigidity of the top.
If your's is plain fiberglass, you shouldn't have a problem but I'd probably make a plywood spacer to give some rigidity around the hole.
Here's what mine looks like:
