Originally Posted by Huntsalot
Off the shelf huh, lol well the high steer arm. After that everything was made. Hard to get everting to clear at the right angles with the 7.3 oil pan
I mean highsteer arms are readily available for the early 'flat top' Dana 60's, which is a good thing. You probably know this, the later ball joint Dana 60's are non-flat top, you have to machine the knuckle to get a highsteer set up on a van, machine the forging to a flat top , key it into the arm, drill and tap holes (or have it done). Then start building the tie rod and drag link. At least, that's what I wound up doing with mine. And you still have the BS ball joints and unit bearings. I like the direction you took.
I see your heims and steering damper in double shear, doubler plates, beautiful TIG welds, your drag link is horizontal, time consuming high-end race stuff. You must build serious offroad cars or something, that fab work is professional grade.
