Old 05-11-2019, 01:30 PM   #151
rltilley's Avatar
Beautiful shots! They keep getting better and better. And I keep getting more and more jealous of your trip!
rltilley is offline   Reply With Quote
Old 05-11-2019, 02:26 PM   #152
Twoxentrix's Avatar
Remarkable journey! "Contrast" Pic's are fantastic & love the video - always enjoy your updates, great Thread.
Old 05-13-2019, 09:28 AM   #153
VanDickin's Avatar
There's blue sky's in Iceland?! Spent a week there a year ago and never saw blue sky.
Hope you got a chance to take a dip in a thermal pool and try the local fermented shark!
VanDickin is offline   Reply With Quote
Old 03-15-2020, 12:08 PM   #154
Big fan of your van Pschitt. I have a E-Series with a Fiberine Hightop. Tried to use 1der's z brackets but that does not seem to work.
Is your awning mounted directly to the fiberglass top? If so, do you mind sharing how you have done it?
Thanks!
hyperdrive is offline   Reply With Quote
Old 03-16-2020, 09:39 AM   #155
Pschitt's Avatar
Hi hyperdrive,
Thanks for the compliment!
Yes, VivaLaVida's awning is mounted directly to the top. I used 3 L shape Fiama brackets that are bolt through the top. The awning is placed above and bolted from below with special bolts, the head of which fits into a rail integrated into the awning. The only point to take car of is the alignment in height and length of the brackets. As my top is curved in its length, I had to shim the front and rear brackets. Easy to install and reliable so long.
Hope it helps.
Old 03-16-2020, 01:23 PM   #156
Pschitt, that is what I wanted to hear. Thanks so much.
Old 03-16-2020, 02:51 PM   #157
Pschitt's Avatar
Your're welcome.
Don't forget to put enough silicone behind the supports to properly seal the installation.
The SMB
Economan
VanBo
Mike Ponce
