Old 11-03-2024, 06:56 PM   #11
It is an inverter,. Thanks for your help and suggestions. We have decided to skip the used and the repair and just buy the DC model that is brand new and fits perfectly. Really don’t need the ac anyway after thinking about it, more efficient and brand new. Thanks!
BonDave is offline   Reply With Quote
Old 11-04-2024, 10:11 AM   #12
Twoxentrix's Avatar
FYI: Before you pull your fridge, there are a couple screws that come out on the black frame around the edge of the fridge, BUT you may also have 2 screws that go through the paneling (which frames the sides of the fridge). The screw heads are usually masked by a ‘screw head cover cap’. Mine were positioned about 4 or 5” from the outer edge of the panels, and about 1/2 way the height of the fridge. May want to check if you have those before you start pulling on the fridge.
