Old 01-24-2011, 11:40 AM   #1
Zeta's Avatar
35" tire adapter for Aluminess swing away
I've been searching through our vast archives, but haven't been able to find the post referring to an adapter plate Aluminess made to fit a 35" tire to one of their swing away tire carriers. Anyone remember?
Maybe I just dreamed it.
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 01-24-2011, 12:04 PM   #2
Re: 35" tire adapter for Aluminess swing away
No you didn't dream it, they did make some kind of an adaptor that off set certain size tires...I just don't recall how large of a tire it was for. Maybe give them a call.
Old 01-24-2011, 12:29 PM   #3
DisabledExplorers's Avatar
I have 35" Nitto Trail Grapplers on my Aluminess swing away with no issues.
Go out and play in the dirt!
DisabledExplorers is offline   Reply With Quote
Old 01-24-2011, 12:55 PM   #4
I'm thinking it depends also on what year the bumper was made. Seems they made a change after 2006 but I could be wrong.
Old 01-24-2011, 02:35 PM   #5
The adaptor may vary with both the size of the tire, and the offset of the rim. The tire needs to be firmly against the tubes of the swing away arm to prevent failure.
I also had to adapt for the bolt pattern change from 8x6.5" to 8x170mm.
Why don't you call Aluminess and find out what you need?
Old 01-24-2011, 08:18 PM   #6
Mine is an 04' and fits a 35" tire no problem.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 01-24-2011, 09:01 PM   #7
I have an adapter plate for Superduty 8x170mm that doesn't fit my bumper or tires and I made my own instead out of aluminium. The tire must compress on the arm or the welds will crack, if you're DIY that's important.
viewtopic.php?f=13&t=2668&hilit=tire+carrier
Still have the plate if anyone is interested.
Old 01-24-2011, 11:12 PM   #8
pjpvi's Avatar
Just give Aluminess a call. They were a huge help when I needed adapters to fit my 35" spare. I sent some measurements and they sent every thing I needed.
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Beatrice
Drizzt
"Campy"
campy
