Old 03-11-2020, 09:16 PM   #1
Added a high top
I finally did it added a high top. Thanks to Vanimal for selling one to me, I added a 19" or 20" fiberine top.
I put solar panel, fan, and traction boards on top before install. It was much easier to mount it to the top on the ground. And installed lights on the side. Then cut the top off glued screwed, bolted it together. Then wired everything and added framing for ceiling and wall panels.
20200218_113828.jpg   20200302_104246.jpg   20200311_200655.jpg   20200220_133415.jpg   20200220_133916.jpg
Craigk is offline   Reply With Quote
Old 03-12-2020, 04:04 AM   #2
marret's Avatar
Well done, looks great.
Chris
Old 03-12-2020, 06:18 AM   #3
Thank you marret.
Old 03-12-2020, 07:46 AM   #4
Kibo's Avatar
Looks good! What is the box up near where the third brake light is supposed to go?
Old 03-12-2020, 11:14 AM   #5
Nice man, looking really good!
CGgonzo12 is offline   Reply With Quote
Old 03-12-2020, 01:53 PM   #6
That is for a water tank shower that is mounted when I need it.
Old 03-20-2020, 04:18 PM   #7
Looks outstanding there. You have been busy. It was hard to tell how nice the top was with all the dirt on it when you took it. The drive home in the rain did it wonders! HA! If I know better you waxed the heck out of that top!
Old 03-20-2020, 04:51 PM   #8
Glen's Avatar
Looks great!!! What are you using to run the power for the exterior lights through the side of the top? Do you have a close-up picture? I've been looking at something similar, but haven't decided on how/where I want to get the power through the top.
Friends Don't Let Friends Do Stupid Things Alone
Glen is offline   Reply With Quote
Old 03-20-2020, 05:21 PM   #9
They are called electrical glands got them on Amazon.
https://www.amazon.com/Plastic-Water...4746464&sr=8-9
Old 03-20-2020, 05:24 PM   #10
Vanimal, I scrubbed waxed then rewaxed then put everything on it then rewaxed so 3 coats. Thank you for parting with it and great to meet you.
Vandemic
Charliesmom
Beni
hildems
