Old 08-11-2020, 03:33 PM   #1
Advice for awning for 2015 Promaster 159
I have a 2015 Dodge Promaster sportsmobile and would like to install an awning. Would you recommend the Fiamma ones that sportsmobile installs? Are they easy to crank for a single senior female? They are just a little pricey to have sportsmobile install at about $2300. What about batwing type awnings? I’ve had several sportsmobiles but none of them had an awning and am looking to travel more now and an awning would be nice.
Suggestions and advice are much appreciated.
Diane
mericatr is offline   Reply With Quote
Old 08-11-2020, 06:08 PM   #2
REF
REF's Avatar
Send a message via MSN to REF
I’ve gone through several other brands of awnings, Fiamma is by far the easiest to operate, I dare say, even for a single senior female.....
They are spendy, but you’ll actually use it, vs. some of the others that require 2 people to set up and stow away or are too complicated to bother, I’ve dealt with both before getting our Fiamma. See if you can order the proper brackets required for the Promaster from somewhere, SMB or another up fitter and contact member 1der for the awning. Where are you located? maybe there’s a shop that could install for you nearby.
https://www.sportsmobileforum.com/fo...65s-23556.html
Old 08-11-2020, 06:34 PM   #3
Thanks so much the advice! I was leaning toward getting the Fiamma one and just wanted to make sure it was worth the cost. Sportsmobile austin did the conversion so I’ll probably get them to install. It’s pricey but you are right that many others require 2 people to setup. I’ve tried some free standing covers and usually just get aggravated. Lol. Looking forward to traveling again!
Old 08-11-2020, 06:52 PM   #4
KDB
KDB's Avatar
I love my 270 Darsche eclipse. With the outward walls (when attached) it's a large additional living space.
KDB is offline   Reply With Quote
Old 08-11-2020, 07:53 PM   #5
Wow that’s nice! The extra walls make it nice. It’s is hard to setup? My brother in law has a batwing type aw8ng with walls on his trailer and it’s great!
Old 08-12-2020, 09:17 PM   #6
KDB
KDB's Avatar
Very easy to open. THey've got some good sales vids on youtube to check out. It's a tight close but it won't take more than a couple uses to dial that in.
Old 08-13-2020, 12:16 PM   #7
Thanks for the info! I’ll check it out.
Old 08-13-2020, 12:52 PM   #8
Otter's Avatar
Another brand to consider is the Thule. I have the awning and like it a lot. Can’t speak for their tent/enclosure but here’s the info on it:
https://www.thule.com/en-us/search?search=Awning
Tags
awning fiamma
