I finally got around to replacing the bearings on my Aluminess swing arms.
I removed the spare tire from the driver’s side and the box from the passenger side. Once I realized that the caps didn’t screw off (thanks @barrel47), I used a rubber mallet and a screwdriver to pop it off. Neither side had a set screw. Each swing arm has a 1 1/8” nut and a washer that need to be removed. Theoretically, the swing arm should be able to be lifted up, off the spindle. However it required some muscle and a few “wacks” from my trusty mallet. The top bearings could easily be taken off the spindle. The lower bearings, not so much. I used a pair of tin snips to cut the dust covers and “wind” them off below the lower bearings. I also cut the cages and removed the bearings off the race. After some penetrol and lithium grease, I was able to turn each race using a pipe wrench and finally slid them off the shaft. I spent the next 30-45 minutes cleaning each of the spindles with steel wool and WD-40. The reassembly is pretty straightforward. You turn the swing arm upside down, clean the inside of the tube and wire brush the bottom to remove any burrs. Install the lower bearing with the taper going toward the top. Finally install the dust cover flush with the bottom, taping with rubber mallet. Spin the swing arm over and insert it over the spindle carefully, push it straight down until the arm slides into place. Next, insert the top bearing with the taper going down. Replace the washer and nut on the spindle and torque the nut to 40# to set the bearings. Then back off completely and re-torque to 25#. Replace dust cap and set screws. I put a little petroleum jelly on the washer in the cap. => Repeat on the other side.
Not realizing what had happened to my driver’s side spare tire swing arm initially, I now speculate that when I last had my tires rotated, the “technician” bounced the tire onto the swing arm and broke the bottom edge of the race of the lower bearing (see pictures), leading to the cap being ajar and the broken bearing. The nut on the top of the splindle and its washer had some rust but fortunately, both spindles looked great after cleaning.
Scott
2019 Transit 350 HR Eco Quigley 4X4
“Vandemic”
