I have experienced two bad starter batteries over the last two months. The replacement for both of them has totaled just over $1,000, fortunately it was fully covered by warranty. This got me thinking that something (other than the batteries) wasn’t working as planned. During both dead battery conditions, the house battery never came to the aid of the starter bank. The Battery Sure Power separator that is provided has a Auxiliary Start Activation circuit wired in by SMB. The way it is supposed to work (on my van) is when the starter bank needs an additional boost from the house bank, the separator will join the two banks together during the start operation. The caveat is that the starter battery must have 3 volts to close the circuit. With only one bad battery in the diesel starter bank I should have had plenty of voltage to trip the auxiliary system, but during both dead battery episodes, the house bank never kicked in.
This made me think that the system (even though it wasn’t working) is probably not what I really wanted anyway. For if the house battery kicked in automatically as designed, there would be little indication that I had a problem with the starter bank. In reading the SurePower documentation, there is a option to add a momentary contact switch to the system to force the banks together. After conversing with Peter at SMBW I learned that they now install this manual switch in the current builds. I remember reading a couple of posts that mentioned a dash switch but never put 2 and 2 together until my problem occurred.
I have now installed a dash switch to manually tie the two banks together. For those with the same type of setup as mine you might consider installing the manual boost switch.
The write up on the installation is on the Wiki Site under Projects.
http://wiki.sportsmobileforum.com/in...ments#Projects
