Originally Posted by capnkurt
I would definitely not recommend going with the coil spacer setup. I tried that in my 98 extended 2wd 3500 and was very unhappy with the results. The ride becomes extremely stiff in the front end, and the new geometry causes issues with the upper control arm constantly coming into contact with the frame at full extension. The shop that installed the kit (a very reputable one) had a really tough time even getting them to go in. The blocks themselves are fine, but the stock rear springs on a 3500 are bone-jarringly stiff to begin with, as I'm sure you're aware.
That is what I was thinking too, that is why I was curious about alternative spindles. I think weld tec makes a great product but for my use his stuff is way way overkill for me. As far as spindles go anyway, to me a lift spacer is a lift spacer no matter whos name is on the box. I can't seen one aluminum spacer being far superior to another if they are both made of the same grade material.
