Old 07-25-2018, 06:31 PM   #21
ShuttlePilot's Avatar
JOELMUNOZ3, posting a pic of the fused adapter would be awesome. Thanks for your help.
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
Old 07-26-2018, 01:16 PM   #22
pic of fused link
here's a pic of the fused link.
part # 8w7t-14a411-ca
JOELMUNOZ3 is offline   Reply With Quote
Old 07-26-2018, 01:19 PM   #23
If that's a recall shouldn't we get it for free?
karma is offline   Reply With Quote
Old 07-26-2018, 01:21 PM   #24
Originally Posted by vandiesel View Post
I swapped steering wheels and now I have no cruise. Are the switches that common of a fail or could I have blown a fuse somehow?
I guess you could have blown a fuse. I would check that first but hopefully you have your old steering wheel and buttons to swap out. May have damaged the clock spring during the swap?
Old 07-26-2018, 06:58 PM   #25
Thank you JOELMUNOZ3 for taking time out of your work day to post a pic of the fused link.
I think I'd have to run my vin # as the fused pigtail your showing has two plugs that don't look like they would fit my van.
Also, I'm not criticizing Ford's design because I like a simple solution to a problem but that part looks like something I made in the garage out of my spare electric parts. So, to that end why couldn't someone just splice in two ATO/ATM fuse holders into their existing harness near the sensor?
Thanks again for bringing this topic up.
- Eric
Old 07-30-2018, 12:37 PM   #26
Jeffrey's Avatar
OK, I got a new one of these. I looked under at my brake lever and see no such component anywhere. I have a 2007 E350. Where do you put this thing?
Old 07-30-2018, 12:58 PM   #27
Originally Posted by Jeffrey View Post
OK, I got a new one of these. I looked under at my brake lever and see no such component anywhere. I have a 2007 E350. Where do you put this thing?[/IMG]
On Master Cylinder bottom front. Electric connector pointing down.
I was able to quickly swap the old for the new with only a few drips of fluid. Did not need to bleed brakes after. Don't forget to put a rag under the sensor to catch drips of fluid as it will remove paint in some cases.
- Eric
Old 07-30-2018, 06:35 PM   #28
Jeffrey's Avatar
Thanks Eric.
