Old 09-14-2020, 10:29 AM   #41
BenJJ's Avatar
More Pictures
BenJJ is offline   Reply With Quote
Old 09-14-2020, 10:32 AM   #42
BenJJ's Avatar
I was able to attach all of the lower panels on the passenger side cabinet. The process was a bit tedious, but once I had it all figured out began to move faster. I am still contemplating how many of the top panels I want to open. Might end up jsut doing all of them. I definitely did decide that i don't need any of the lower ones to open because I don't want my gear in between the cabinets to block access, or have to unpack stuff to get access.
Old 09-21-2020, 09:45 AM   #43
BenJJ's Avatar
Finished the lower portion of the driver side yesterday. Seems to be coming together well. Picking up the van from CCV this Friday so will be able to install them in a few weeks. Will probably start a full build thread once I get the van back.
Old 09-21-2020, 03:03 PM   #44
Twoxentrix's Avatar
Not only does it look good, but that should weather nicely. All in all its definitely a cool project.
Old 09-21-2020, 04:33 PM   #45
BenJJ's Avatar
Thanks! I can't wait to get them in the van to see the final product. I am salivating while planning how to utilize all of the storage. I think I will be able to fit the large majority of my gear inside of these things. Tables, chairs, dry food, Pack-n-play crib, battery buddy, 1-ton jack, tools, water tank/pump/heater, electrical.... I could probably fit a good chunk of my cooking gear as well, but ultimately want some sort of slide out kitchen built in between them.
Old 09-21-2020, 05:26 PM   #46
Great stuff! Have you open-sourced those 3D printing design files?
... Bob
2006 Sportsmobile SWB
E350 6.0l
graybeard is offline   Reply With Quote
Old 09-22-2020, 05:44 AM   #47
marret's Avatar
Agree, look great. Well done.
Chris
Old 09-22-2020, 07:57 AM   #48
BenJJ's Avatar
I have not. If you would like the .STL file PM me and I can send it to you.
Old 01-24-2021, 10:50 PM   #49
Have any new updated pics to share of your cabinet project?
leblanc is offline   Reply With Quote
Old 01-25-2021, 08:40 AM   #50
BenJJ's Avatar
I ended up finishing the build within the build thread for the van itself located here:
https://www.sportsmobileforum.com/fo...ild-27129.html
here are some pictures of them finished and installed.
ADVMOBL
Botchan
Clyde
ormtnbiker
