Old 02-12-2010, 05:37 PM   #1
woodbee's Avatar
Electric penthouse clearance, floor to ceiling
The fabric sides of my penthouse have never been very tight, I can always see large wrinkles when it is up. I have an electric lift system. The measurement from the floor to the ceiling is 6' 7.5" and it is suppose to be 6' 10". I was wandering if anyone else has this problem. If possible I would like to here what measurement others with an electric lift system have. All the pictures I see on the forum of other penthouse tops the fabric looks tight.
Thanks,
Woody
2009 White E-350 Modified EB-43, 4x4, 6.0 PSD
woodbee is offline   Reply With Quote
Old 02-12-2010, 06:31 PM   #2
Greg In Austin's Avatar
Re: Electric penthouse clearance, floor to ceiling
Is yours the portable or built in lift?
Ours is built in and the sides are tight.
Are your bars straight?
Greg in Austin
Old 02-12-2010, 06:47 PM   #3
woodbee's Avatar
I would say they are built in. I ordered the electric lift when I placed the order.
Old 02-12-2010, 07:30 PM   #4
Are the crossbars that hold up the pht bent?
Greg in Austin
Old 02-12-2010, 08:39 PM   #5
woodbee's Avatar
Greg,
The cross bars are not bent. A while back I was checking out the tracks, at the end of each track I noticed about an inch of travel left when the actuator stops in the up position. That inch of travel would probably give me the 2.5" up.
I talked to Peter at SMB and he said there is no adjustment.
Woody
Old 02-12-2010, 09:39 PM   #6
There is always a way to make adjustments.
I think on the manual tops there is a chain and springs.
I would think that with the electric there are either stops or sensors or travel limits that could be adjusted.
What did SMB say about the condition of the top not being all the way up?
Greg in Austin
Old 02-13-2010, 02:59 PM   #7
I thought there was a block or something on the electric lift that changed where it stopped, but it might be the manual PH I'm remembering. Search with John Kalmbach as author he's provided a ton of great info.
Old 02-13-2010, 07:12 PM   #8
woodbee's Avatar
Thanks for the input, the problem should be resolved tomorrow.
Woody
