Initial seat prep is pretty much the same as how you would have done it using the MG risers or U-joints i assume. You have to cut off the metal lip on the one side of each seat. Then the rod that runs from side to side must be cut out and that area ground down smooth on each side so the new bracket can sit flush against the inside of the seat. The latches must be removed as well as their cables and the release lever at the back of the seat.
When its time to bolt the new bracket in the seat DO NOT try to reuse the original bolts that held the rear latches in place. They are a tapered bolt and they wont tighten down far enough to secure the bracket. If you tighten them up they will go in about 3/4 of the way and then they will wedge in place and you wont be able to get them back out without snapping them off. Dont ask me how i found this out. Just goto your local hardware store and buy some grade 8 replacement bolts.
All of the metal i used is 1/8th inch wall. The side pieces measure 2" wide, the larger peice of angle iron is the rear of the bracket and it measures 2"x2", the smaller piece of angle is the front and it measures 1.5"x1.5". The smaller piece of angle is positioned so as to not interfere with the recline mechanism as well as line up with and locate the electric slider so that it also does not interfere. Note that the side pieces all have a 45 degree cut on the front. This cut is required in order that the bracket will slide down into the seat far enough. By the way, these brackets are square, i have a wide angle lens on my camera when i took the pics so it gives a fisheye effect.
If i had access to a plasma cutter i would make some fancy smancy cuts on the brackets to lighten them up and make them pretty but i dont have that luxury and you cant see them once their bolted in place so no biggy.
Also note that i built the brackets this way because the seats have to be offset to one side. Doing it this way simplified making the brackets that bolt to the floor.
I will post more on sunday when i do the passnger seat.... if its not raining again.
