Okay. Not a first hand Excel user but a bit of feedback anyway -
The Excel is rated for "indoor" use because they have an Oxygen Depletion Sensor to shut the unit off when O2 levels have dropped enough in the "indoor" area. It is still drawing combustion air (O2) from the space it is mounted and operated in. It is still putting out "some" CO due to combustion and it is putting out a lot of water vapor into the "indoor" area as result of combusting propane.
So "Vent Free" in a van will work w some windows open if you want to have the hot exhaust air and water vapor present.
You can put your Joolca inside and pretty much get "first hand" experience on what you will get w the Excel. Only diff between Joolca and Excel is going to be the ODS.
Like I said, no first hand Excel experience but .......
