Old 06-22-2018, 08:41 AM   #1
Jsweezy's Avatar
Ford 4wd Rear Shackle Flip
I originally posted this on the expo forum because their photo hosting is quicker but I wanted to also move it over here because I like you guys more . I put some photos up over there but if you want to see anything that isn't on there let me know. Thanks!
https://www.expeditionportal.com/for.../#post-2491405
Hey everyone,
I just finished up with my 4wd conversion on my 2010 Ford E250 with a coil kit I purchased a while back and wanted to share with you all how I went about making the rear match the front.
So instead of using conventional rear lift springs from Deaver or Atlas or just slapping some lift blocks under the stock springs, I noticed that the "Bolt pattern" on the rear shackle hangers for the E-Series vans happens to be the same as the ones on the 1978-1997 F250s. I also knew from my past life before vans that Sky's Offroad Design aka Sky Manufacturing here in Springfield Oregon happens to make a shackle flip and heavy duty shackles for those year trucks. Knowing that those trucks are rated to carry way more than ill ever have over my rear axle in my van I decided to give it a try and if it didnt work out I could always just bolt the stock ones back on. Another plus of using a rear shackle flip kit is that not only does it lift the rear, it also moves the axle forward as well as repositions the pinion so it is pointed further up than it would when it was stock. This means that it basically adjusts the rear to do everything you would need to do anyway with the lifting of the rear end.
Before I get into it how it worked out I also want to state that I am running a 2014 F250 rear axle (I have rsc so it had to be the newer axle for RSC compliance) so that may have something to do with how things worked out but the wheels are just as wide apart as anyone with rear wheel spacers would have using a stock van axle. I also have Fox shocks in the rear but they aren't anything custom other than the high clearance mounts on the axle.
So I initially started with purchasing the shackle flip kit (https://www.skysoffroaddesign.com/co...s/ford-rfk-001) and then sweated for a month or so hoping it would actually work. I waited on purchasing the rear heavy duty shackles because Sky also offers a 1" lifted heavy duty shackle but upon realizing that would move my axle further forward than I wanted to I just went with the stock length heavy duty shackles (https://www.skysoffroaddesign.com/c....-rear-shackles). One other thing that I ended up doing that I didnt plan on was having to purchase an add-a-leaf to account for another 1" or so of lift that I needed to match how tall the front of the van was after using MG's coil kit with the CC880s Springs and having a 5.4l engine. I went with this one here that came with everything I needed to add the leaf (https://www.generalspringkc.com/prod...e350aal923.htm) and as you can see it not only lifted the rear but also added an extra 1492 lb to the spring capacity.
Well after all of that I am happy to report that the ride is phenomenal. Not only did it lift the van but the rear sway on this high top van is non existent. Before I converted this van to 4wd I had to order a rear sway bar from hellwig so that I could go around a corner without feeling like I was going to fall out of my seat. Now I haven't even installed the sway bar back on and the rear end is so solid I never plan to put it back on. The longer leaves also make it for a firm but soft ride over bumps. The ride matches the way everyone is always trying to get their trucks or vans to ride and is usually only attained by "adding weight to the back" but I haven't added anything other than whats listed in this thread.
Overall I am extremely happy with how this turned out and see it as a viable option for anyone else doing a conversion for their van or having issues with axle wrap or a stiff ride. I will be attaching a good amount of photos in the next post because, "Pics or it didn't happen!"
Feel free to hit me up with any questions!
EDIT - Something I forgot to add was that I did have to "dump" or cut the exhaust where it comes down after going over the axle because otherwise the leaf springs would have been resting on it.
Old 06-22-2018, 09:38 AM   #2
Wanderlust Bus's Avatar
Subscribed.
I need to beef up the springs on our van, so I'll be following this post to get some good information.
Wanderlust Bus is offline   Reply With Quote
Old 06-22-2018, 10:06 AM   #3
Jsweezy's Avatar
Well there really isnt much else to add unless you have specific questions. I wouldnt say this is and end all to lifting the rear of a van because I dont know how it would handle all situations (towing?) but for a fairly light cruisier with a 5.4 that wont see much other than hauling people as a light camper this seems to be the way to go. Most if not all new trucks have the rear shackles like this so I'm not too worried if I do have to tow my 3500# trailer.
Old 06-22-2018, 11:32 AM   #4
WhitH's Avatar
Genius! And thanks for the heads up on Skys. I didn't know about those guys and they are right down the street from the diesel and offroad shop I use.
Sold 2005 E350 Chateau
Old 06-22-2018, 12:30 PM   #5
Jsweezy's Avatar
Thanks! And really it was a crazy idea, I think I just got lucky while laying in bed one night thinking about my van... Ha ha
Old 06-22-2018, 12:30 PM   #6
04QuadBear's Avatar
Its cool to see Sky's business pop up on here. He is an old friend of mine, actually the best man at my wedding. I have been bugging him off and on to prototype some more van parts. Neat to see his stuff cross over to the vans.
04QuadBear is offline   Reply With Quote
Old 06-22-2018, 01:02 PM   #7
Jsweezy's Avatar
Thats awesome. Yep, he has already designed stuff for the van world and didn't even know it.
Old 06-22-2018, 02:43 PM   #8
WhitH's Avatar
Let me know if I should be another person to bug him about it....
Old 06-23-2018, 05:24 PM   #9
MSD
MSD's Avatar
Dang the van looks killer! It makes the top look good too. Now I really wish I put this top on my van. Oh well maybe the next build. I was gonna use the General spring add a leaf but decided on the 5k spring pack for towing & the extra 2” of rear lift. The rear shackle flip kit idea was brilliant
2003 Land Rover Disco II
1997 E350 7.3l 2wd - Sold
Old 06-24-2018, 10:26 AM   #10
Excellent! Thanks for sharing...
So you have to grind off the rivets to get the new brackets bolted on, correct?
I'm thinking about this to lose the 2" lift blocks I'm using now; sounds like I'd also need to remove a few leafs to end up where I am now lift-wise.
Josh: Since your last van was an Advanced conversion, do you have any brilliant ideas for moving the front axle forward say 1/4"-3/8"? That would likely fix my tire rubbing issue. Thinking about putting 1/4"-3/8" steel plate shims between the front leaf mounts and the van frame horns......
Rattle-n-hum
dar636
Dodge
lugee
