Old 07-01-2010, 10:23 PM   #11
geoffff's Avatar
Re: Front axle shaft seal leak
I'm using Budd & Co. http://www.buddandcompany.com/ -- because they're honest and located close to my house.
Yes, they have now seen my Sportsmobile, but I've got to say they're still pretty flummoxed by it.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 07-17-2010, 08:32 PM   #12
My Dynatrac has developed this leak as well on the driver's side at 41k miles. I am getting both sides re done for $350 at a local 4x4 shop.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 07-17-2010, 10:58 PM   #13
Bones_GSXR's Avatar
My early post said that Dana 44's and 60's did not have a outer seal. I have now found out that this is incorrect. Starting with the '99 Superduty the Dana 50 and 60 have this outer seal. Spicer does make a replacement but you will nee to replace the hub seal as well.
Old 07-21-2010, 01:15 PM   #14
I had this fixed yesterday by a reputable 4x4 shop. On the Dynatrac the seals are inboard at the differential. $344, not too bad.
Desert Solitaire
2003 7.3L EB 4x4
Old 07-21-2010, 01:38 PM   #15
Roonie's Avatar
That is a great price! I guess they had to redo your wheel bearings at the same time since they were in there? or did they go through the case?
Old 07-21-2010, 02:30 PM   #16
Funny thing is it started leaking after I had the bearings re-packed. Figures.....
They pull the spindles, axle shafts, carrier, etc. to get to the inner seals. They had it done in 5 hrs.
Desert Solitaire
2003 7.3L EB 4x4
Old 07-21-2010, 08:59 PM   #17
Even on the front axle? When they did mine, the guy didn't do a good job, got some debris while installing the seal(s) and I developed a leak. He said to park it on an angle to let it drain. But it never drained and continued to leak. I took it to another shop who said he scored the inner seal when installing the seal/axle. I don't know jack when it comes to that stuff but it seems if the inner seal is conpromised it will leak. Possible???
Old 11-12-2010, 02:48 AM   #18
figure a full weekend to do an inner seal if you have some mechanical knowledge and want to do it yourself. five hours is probably reasonable, except if they score the seal and you have to get it done somewhere else
dimension4 is offline   Reply With Quote
Old 11-13-2010, 10:19 PM   #19
It did cost me but under 500 bucks. The other shop said they will compensate me. Really don't want to take the SMB back there though
Old 05-19-2017, 03:53 PM   #20
Argg, I noticed this the other day when we were wrapping up our last trip. Leaking out of the passenger side of my dynatrack front diff exactly like yours. Need to find a 4x4 shop in Flagstaff. I'll report back when it gets done.
Whats the danger driving this in it's condition? Can I just make sure the diff fluid levels are at proper levels for some short trips, and to the shop?
2006 E350 Sportsmobile 6.0
https://phlite.net
phlite is offline   Reply With Quote
