Old 04-13-2020, 01:47 AM   #11
Kibo's Avatar
Nice, glad it's being put to use! Thanks for the pop-out trim, psyched to finally find some!
Old 04-14-2020, 09:36 AM   #12
Originally Posted by EddieTheVan View Post
Got mine swapped, just had to Dremel a hole for the door saver straps. Thanks for the panel Kibo!
EddieTheVan, Did you make that door saver strap? i have to replace my passenger door since the wind caught it at a gas station while driving through Wyoming off the 80. Completely separated the panels and made it so i couldn't fully open the door, so this solution looks really good to help prevent this from happening again!
2004 E-350 Hi-Top, 6.0psd, 33" ko2's, Timberline 4x4
DHwreckage is offline   Reply With Quote
Old 04-14-2020, 10:18 AM   #13
EddieTheVan's Avatar
No I didn’t make them, my van was an old DHL van and they installed them on all of their delivery vans. You can definitely buy door saver straps though. There are a lot of options for Jeeps that would easily work:
https://rover.ebay.com/rover/0/0/99?...3D382852798783
EddieTheVan is offline   Reply With Quote
Old 04-15-2020, 07:15 AM   #14
Those are extremely slick and VERY useful. There's been a few threads here and on FTE too asking about such things but no one (including me) ever thought to look at Jeep parts.
Thanks for the info.
Old 04-15-2020, 09:09 AM   #15
I hate to be a buzz kill, but I have to say, the jeep ones are kind of wimpy and not designed for a heavy van door. Might try the older econoline style.
https://www.macsautoparts.com/ford_e...strap-kit.html
Old 05-17-2021, 09:47 PM   #16
I found some heavy duty straps. Kind of expensive at $135 for the pair.
https://warriorproducts.com/heavy-du...-kit-pair.html
I sent a message to EddieTheVan to see how his are mounted up.
1998 E350 7.3 Hightop
r27d is offline   Reply With Quote
