The only thing that keeps me awake nights in my new (used) SMB is the fear of a gas (CO or LP) leak gassing me and my family. The detectors in the SMB were the originals, and they're past their expiration date.
Another issue with the original detectors was their huge current drain. I couldn't believe it when I read how much current they draw. Add to that the test procedure involving spraying butane into the detector (both LP and CO), and I was ready to cut them out and put in new ones.
Fortunately technology in the last few years has produced a combination CO & LP detector in a single package. It draws about 100mA, and is tested simply by pressing a test switch, no butane is required. It was this unit I decided to purchase to replace the originals.
The unit I selected, a Safe-T-Alert combination CO / LP detector, has some pretty tricky limitations on where it can be placed. It had to be within 20" of the floor. It couldn't be within 1 foot of a door or window or HVAC vent. It could not be placed on an exterior wall.
I couldn't use the location of the original propane detector, since it was too close to the door, and I wasn't sure there was sufficient free space behind the wall.
I couldn't reuse the location of the original CO detector, since it was mounted on an exterior wall, and was much more than 20" off the floor:
After some deliberation, I decided to mount it on the long door under the rear bench seat.
First step was to remove the door, then mark off a suitable location for the unit and drill some pilot holes:
The holes were widened with a larger drill bit, then cut out the mounting hole:
The detector finally mounted in the door.
Now to wire it up:
Note that these detectors have a date stamped on the back. They're good for 5 years at which time it's a good idea to replace them.
