Originally Posted by HK33FAN
Is this highlighted area the crack. If so grind a V into it with a Dremel tool or burying bit so you have a rough surface to adhere too. then add a good layer of JB weld or any good two-part epoxy. cleanliness and a very rough dry surface are key.
I have also had good luck with Flex Seal rubber spray paint, take a few coats.
Yup, I think that's it. Are you saying to make the cut deeper?
Originally Posted by Scalf77
Thanks! How did you do it?
EDIT: Opened the link and there's literal video instructions, awesome. So I'm guessing it's ABS plastic then? Where was yours cracked? You think I can just apply some of that resin along the crack or do I need to add extra plastic and stick it on top like they fix that hole?
