Old 11-06-2024, 07:19 AM   #1
Holding tank - sources?
I may need a new grey water tank. Was checking on them and I can't believe the prices.. $250 for a 10 gallon plastic box?! Anyone know where one can find these tanks for a reasonable price? - Thanks
N147JK is online now   Reply With Quote
Old 11-06-2024, 09:25 AM   #2
1der's Avatar
PM me with size and zip code. I might be able to save you some $$.
Old 11-06-2024, 09:48 AM   #3
Thank you 1der. I'm still trying to rescue the one I have, but if it doesn't work out I'll contact you.
Old 11-06-2024, 09:54 AM   #4
1der's Avatar
What is wrong with the one you have?
Old 11-06-2024, 10:17 AM   #5
Well, the drain fitting was broken when I bought the van. No big deal I thought, I'll fix it. Little did I know how difficult polyethylene is to work with. Spin weld - nope, don't have the tools. Heat gun weld - nope, plastic doesn't take to welding, made a big mess. Adhesive - maybe, but polyethylene is notoriously difficult to glue.
The spin-welded polyethylene tanks are great.. until there is a break - they are difficult to repair at home.
Old 11-06-2024, 10:41 AM   #6
I just got one from ClassAcustoms . com. I thought it was very reasonable.
Available on Amazon but cheaper thru their website with free shipping.
kbeefy is offline   Reply With Quote
Old 11-06-2024, 10:44 AM   #7
https://www.classacustoms.com/10-Gal...Tank_p_12.html
$50
Old 11-06-2024, 10:45 AM   #8
1der's Avatar
Yep, welding PP requires a plastic welder. You can get one at Harbor Freight that will do the job. Spin welding - router with the proper bit.
So, the fitting itself was cracked down the threads because some one over tightened it?
One piece of advise for PP tank threaded fittings - DO NOT use the Teflon tape. That build up will put lots of pressure on the fitting. I use Rector Seal exclusively for those fittings.
Is there enough of the tank side fitting exposed that you could put a hose clamp around the perimeter? If so, a plastic weld on the outside of the fitting plus a hose clamp and Rector Seal on threads might just do the trick.
Old 11-06-2024, 11:07 AM   #9
Originally Posted by kbeefy View Post
Thanks - great price, but need different dimensions. Current tank is 30LX10WX9H.
Old 11-06-2024, 11:20 AM   #10
I bought a welder and tried it. They will melt plastic, but melting two pieces of heavy plastic together (weld) is beyond what they can do. I just created a mess and lots of smoke!
I'm going with the rubber grommet as pictured. Superior I think because they seal well and are a bit flexible and will take a little shock. The spun-weld fittings are rigid - if they crack, break, or leak, they are very difficult to repair.
But I need to put a new piece of polyethene on the end of the tank so I get the right size hole. Thinking of trying the 3M DP8005. I don't like using glue for anything, but it might work.
