arctictraveller, I understand what your experiencing and I too would think, "man, I've been parked here for hours with the windows open and the exhaust fan on, why is it still so warm in here?" I don't have much experince with products you could place under the carpet but I'll share the three things that made a huge difference for me to cool down after driving. Disclaimer, these may sound obvious here but it is my experience to have helped the most. Also this may only apply to a 6.0 van.
Eleven years ago when I installed the now gratuitous to SMBs transmission cooler. Having 5 gallons of ATF and metal under the floor at 165 degrees vs 220 degrees made a huge difference to the heat soak situation.
Bedliner the roof white. Not really a heat soak issue but it made a big difference in the overall heating up of the van.
Finally, this is a no duh, open the hood for the first hour after stopping for the day. Even with hood louvers on my van I still open the hood for the first hour or so to get the heat out, unless it's fairly cold out. It dose attract the good sanitarians to ask if I'm broken down if I'm in an area where people don't open hoods overnight. I've been in many areas where folks open their hoods overnight to prevent wildlife from spending the night or chewing things up. On this same note, if I'm able, I will park with the nose into the prevailing wind to help with the cool down, even if I have to briefly restart to reposition for the night.
- Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
